- Hammertown, USA
Oh, i think that would apply very directly - KOH may be a mixed breed race, but there's still a hundred miles of desert involved.
I wouldnt agree with that statement.
there is most definitely a benefit to coilovers. tell me where your dual rate slider and stop ring is on a coil spring?In part, yes. But only because they know that once you are tuned properly, there is no benefit of a coilover to a coil/shock combo. Other than the packaging issues which Dallas solved nicely.
there is no perfect spring rate for any two rigs. weight and setup can be completely different between two tj's. i know my corner weight is a lot lighter than the OP of this thread, so my spring rates might not work for him and vice versa.Which part ?
Before you answer, let me preface by saying that it is much easier to tune a coilover. Currie has spent a ton of time dialing that coil in for the tj/lj platform. As far as coils go it is hard to beat. Blaine has gone even further and spent countless hours on multiple rigs getting a damn near perfect shock tune.
Getting that kind of a tune in any rig is not easy. Especially if you run heavy.
I still argue that putting coilovers in the rear and bypasses up front is much better upgrade for an XJ (unless you do
Both.)
no, not they don't.My progressive rate coils achieve essentially the same thing.
no, not they don't.
someone needs to come up with a bypass coilover lol
I'll have to check them out. Air that means you can tune them on the fly. That really puts them over the top. I know a lot of guys complain about slow compression or not enough, but if the port is big enough you can set them up with dump valves for quick release and emergency situations!
Well, I hate to interrupt the debate but the coilovers showed up today. They are pretty sharp looking and well made as far as I can tell. Of course I got a little excited and had to put the springs/ hardware on one of them. Is there any reason why that could be a bad thing if there's no nitrogen in them yet? They said to put 50-60 pounds in them for mock up/ cycling, so I'm hoping a cycle or two with no nitrogen won't be an issue. I wouldn't think so.
Anyway, school is probably going to get in the way for the next couple weekends so it'll be a little while before I can start mounting them unfortunately. I'll keep you guys posted. Oh yeah, and it looks like the preload adjuster has holes for a wrench maybe? I didn't see one on their site?
