Is it possible to push it back to Sat.? I found out tonight that I have to work Fri. night. If not dont worry about it, Ill try to make it if I can, or Ill make it to the next one. Here are the directions for those of you that are going. From Shaw Ave., west of 41, or east of 99, take Sequia/VanNess south. The actual street will be Sequia going south, but it is VanNess to the north, and is posted along Shaw Ave. with both signs. Then turn into the first drive way on the east, into the parking lot behind the businesses. Drive all the way down to the end of the parking lot, or complex and enter through the last hallway to the east, going throuth the building. Once you enter the hallway, the door to Petes Teriaki is directly in front of you. It may seem difficult, but it will make since once your there. To make it a little easier, Sequia is one stop light west of West Ave. and Petes is located almost directly behind Dicicos on Shaw.
Chuck, thanks for the LCA's, hope I didnt wake you up, looked like all the lights were out. How much do I owe you, or you want to call it a dinner or two or three or... Thanks again, one last thing I didnt look at them close yet, but is there a definate difference between right or left?
