CW. said:
P.S. This is probably a dumb question but what is K.I.S.S. ? :anon:
Keep It Simple Stupid (K.I.S.S.)
The "birdcage" is a nice name for linkage mounts on an axle, and one of the "birdcage" variations (used on older drag racers) is a "full floater" caged axle housing bracket.
I mention the full floater "cage", as it allows the axle housing to rotate (float) inside parallel brackets, with a leaf spring mounted to the bracket. The axle is allowed to float in relation to the bracket cages (and leaf spring), so only the control arms (or traction bar) locate the axle. The axle is located in the cages (right and left side cages) with a tab welded to the axle, located inside each cage. This allows a rigidly welded traction bar (or arms) to always keep the pinion pointed at (or parallel to) the trans output, to minimize driveline problems with a drag racer, and eliminate axle rotation loads from torquing the leaf springs into an "S" shape. It is a very heavy and complicated way to prevent spring wrap. It also creates considerable wear where the axle rotates inside the cages (not too good for a daily driver).
A floating cage can also be modified to allow you to use a traditional leaf spring mount and control arms, without binding the axle (a variation on what Mad MaXJ mentions). The leafs keeps the cage oriented in the same way a lower control arm works, and the upper arms control pinion angle rotation. It has the same problems with wear.
The rigid (pinned) half of the leaf springs will still force the axle to travel in an arc, regardless if the axle is caged to float (with arms bolted to a cage bracket) or controlled with welded brackets (both leaf pad and control arms bolted to brackets welded directly to the axle housing). Cages add considerable weight, and once the wheel travel grows beyond a few inches they lose any real advantage over a true (well designed) linkage suspension.
I would stand back and remove the topic of how to spring the suspension (1/4 eliptic leaf, coil, coilover, semi-eliptic leaf, etc.), until you decide how to link the suspension. When you mention a goal of keeping the back seat and floor, you will limit what you have room to fit any suspension, and the rear leaf springs begin to prove themselves as a good compromise between the space available and simplicity (with a traction bar for pinion angle control).
If you can excuse the penetrations needed for coilover shocks and a cage it can be much more space efficient than any leaf system. The 1/4 eliptic leaf pack can have an advantage of a progressive spring rate, but it will weigh quite a bot. Old Class-8 & 6 off-road racers were forced by the rulebook to use leafs (suspension must use stock spring type: leaf or coil) and 1/4 eliptic leaf packs were a way to bend the rules. The result was good given the rules, but coilover shocks and mechanical linkage systems quickly replaced leafs in any configuration (when Trophy Trucks replaced Class-8 as the premere cubic dollar unlimited class).
Have fun with tossing out ideas (and
the ribbing), but the advice to K.I.S.S. is good for a reality check.
