fenns7
- London; UK
OK, altho' I try to do much of the work on my XJ myself -with help from the experts on this site - there are some jobs where I neither have the facilities (I have to work on-street) nor the ability which I hand over to a local mechanic. To date he has done a great job at reasonable price and doesn't get upset when I print off XJ specific instructions/guides to help.
A couple of years ago he replaced the original drum brakes (by then 20 years old) but on collection there was a distinct rubbing noise which I took to be a lack of adjustment on the brake shoes. I did a couple of very low speed hard stops to try and force an adjustment and I recall a bang and the rubbing noise continued so returned the XJ for him to sort it out. He took the drum off and filed something - maybe the shoe edge - but I wasn't paying close attention.
Anyhow, the noise had stopped and the XJ has been ok for two years until a few weeks ago when a 'dragging' noise started again and I decided I would attempt the job myself - confidence restored by the great tutiorials and photos on this site.
Here's what greeted me when I opened up the brake shoes:
That's the trailing edge shoe on the right side. That's some force applied to bend that :shocked: Here's the end of the brake cylinder that the 'toe' on the shoe would have pressed on:
The left side was a mirror image:
and this shows the extent of the bend in the brake shoe arm which also bent the metal retaining tab - both circled:
So, how did this happen? Everything seemed to have been fitted exactly as instructed - even the green spring that holds the arm to the star wheel had been correctly orientated (an otherwise v. common error) - so he'd taken care. I'd really like to have opinions on what went wrong here so I can advise him - I'm sure he'll credit me the cost/labour against future jobs.
The inside of the drum itself was scored up where the top of the brake shoe was distorted so I've replaced the entire drum brake unit myself which was a big learning curve but very satisfying and I now own another set of new tools !
What was impressive was the handbrake (e-brake in the US) worked well and still held the truck on steep inclines and other than the recent noise gave no impression anything was wrong!
