FatXJ
- South Range, MI
I took my doors off a couple days ago and went wheeling today. The problem is that it takes forever to unbolt the hinges from the door and then to reattach looks like it will be a hassle too.
So I was thinking I could buy pins to put in the hinges so I could pull them off faster, or I also thought about cutting the lower plate off the hinge and welding a bolt to the upper plate so that i could drop the door on the hinge and then put a nut on it to hold it in place.
What did you all do? Also how the heck did you get the roll pin out of the hinge? I have tried everything but a press to get them out and have accomplished nothing.
