They are junk. When we first did this I did not lament that we were not able to get fenders.
The second time I was like.....hey, sure why not, $50 isn't that bad, lets get em, it will save me the hassle of having to hack up some US fenders.
So I get them finally, I'm all excited so I can finally get to work on my front end and check things out. And no disrespect to chris because I know its not his fault, but between all the shipping and everything, they just get too beat up.
Now lets say in future orders we get lucky and the fenders aren't beat up. They are of such poor manufacture I think it will take more time to get them to fit correctly, I will take some more pics tomorrow so you can see what I am talking about.
For starters, there is extra material in the a pillar area that keeps the fender from sitting flush in. That needs to be trimmed.
The edge where the fender meets the visible part of the windshield A pillar on the outside is an easy place to see an aftermarket fender. only the OEM tooling really duplicates the curve right, aftermarket parts don't goto the trouble to fit very flush. If you've seen the aftermarket parts I am talking about then you know what I mean on the windshield pillar area. These alexparts fenders are the worst I have ever seen they just sort to end, basically an edge, no curve to fit up.
Up around the top front edge where the fender meets the header the metal is bent over the front vertical support, when its bent over on most it gets squared off nicely, these end up with a rounded edge that not only would have a poor fit against the header panel(if I could even get them to fit together) but during the stamping process the metal becomes distorted and is wavy, I dont even want to think about what it would take to smooth that over properly.
Next up is the bit of bracktry that bolts up to the header, as I posted before the upper mount to attach the header panel is the same style as the 97+ fenders.
Well when you look at the 97 fenders its fairly thick steel that the mount bracket is made from, something like 1/8th inch. On this alex fender the same bracket is stamped from the same thin steel as the fender is, I don't know what gauge it is, but its thin, thinner than the sheet on the cheapest aftermarket parts you can buy here.
Now on top of that, the mount is so poorly copied that it forces the header panel to sit nearly a half inch further forward than it should, I simply cannot get the header to sit all the way back as it should.
Like I said before, the sheet is thin, real thin, real tin, the fenders just sound tinny, cheap, bad.
Little things are off too, know those slots that the rubber hood bump stops rest on? Well one of them is crooked on my fenders.
Today I bought two OEM fenders at the junkyard. I have an aftermarket US fender here I am going to practice modifying on, then I will move onto my "good" fenders.
Now that we have some chinese ones to use as a template, I plan to make paper templates, scan them in, and then other people can print them, and cut them out to modify good US fenders.
The 2500 fenders were a waste of money, I wish I had not bought 2 sets of them.
