Yup finally got around to installing the pile of stuff onto my XJ(Rubicon Express 3.5", PORC SYE.)
In the process there were some things that bothered me, not real problems, but just...wtf.
The spacers that RE gives you for the bottom of the sway bar links are only drilled to 3/8". The splined bolt you have to remove, and the new bolt they supply are both 1/2". Wtf?
The RE1600 track bar uses a 5/8" bolt, but the bracket that it says must be used with it, only has a 1/2" hole. Another wtf?
The PORC SYE doesn't come with driveshaft bolts. I had to rob them from my front shaft and drive around 2WD for the first 3 days of having my lift. Then had to spend $10 on 4 bolts from the dealer. Weak.
All I've done is drilled all this stuff out to proper sizes, if I was wrong in doing this somehow please let me know.
I'd post pics for you guys, but small electronics have a short life span around me.
