Never did this before so bunch of dumb questions.... found a nut with a busted bolt in the driveway...inspected underneath and it was the passenger side outer ubolt on the rear axle for the leaf spring. I will have new bolts tomorrow, but was wondering about some details of doing the job.
1. getting weight off the springs: I assume if I lift it under the differential then jack stands on the end of each tube, is that the way to go? How do you tell if enough weight is off?
2. I figure it only makes sense to replace all 4....my fear is if I just change the one that broke or one whole side that it will affect height and then affect alignment and i really don't want to have to get an alignment done. I'm sure the other 3 are ready to break too if one broke...
3. Should I put the new bolt on without removing the one that is still in place or do they both need to go on at the same time? It would make sense to me to leave one in to keep it held together while you put the good one in.
Is it dangerous to drive it with a broken bolt? What if both were broke?....I'm definitely replacing them but just wondered because I was driving about 70 on the last trip I took before getting home to the driveway and finding the broken bolt. Please post any info any write ups that may be around. I really only found one video on youtube of a guy doing it, and it didn't really answer my questions.
