GoliathJeeper
- Winnfield, Louisiana
I went 125 in my 1997 XJ. Brother's father-in-law is a state trooper so I got him to check it for me.
XJs are goverened to 117.GoliathJeeper said:I went 125 in my 1997 XJ. Brother's father-in-law is a state trooper so I got him to check it for me.
PAXJ said:XJs are goverened to 117.
boise49ers said:Your 6'8" and you drive an XJ ? ? ? That is a tight fit.
jfox21 said:does the governor run off of a separate spedo gear? im confused how it can be correct if your speedo isnt.
SBrad001 said:I'm 6'7", and love my XJ, fits like a glove!
Now, back to the thread. . . .
There are two circuits(?) that initiate the governor: the first kicks in when activated by the tach/rpms, and the second activates when you hit the limited speed setting.
Both are tied in to the electronic ignition system, which has the governor built into it.
Switch out your ignition system for a MSD unit and you can set your rpm limitor where ever you want. I'm not sure if that affects the speed limitor.
And at any point in time I've been incorrect, please, Dr Dyno correct me.
db209_2000 said:Not many places to race here in Albany, NY. On a straight section of I-787 I had just gotten the speedo pegged (100 MPH) when I caught a glimpse of a po po coming down an on-ramp. Thank God for manual tranny engine braking!!!
'98 4.0L Sport, 5-speed, bone stock, 3.07 gears.
"When it comes to being the soothing light at the end of your tunnel, its just a freight train coming your way." - James Hetfield
db209_2000 said:Thank God for manual tranny engine braking!!!
60thAnivrsryXJ said:Automatic transmissions have engine braking too. Thats what manual 3rd and manual 1st/2nd are for on the AW4.
