1990 MJ
- Puget Sound, WA
The matting under your carpet or mats won`t dry untill it`s removed and hung to dry for a few days. Which means you will have to remove the seat to get the carpet out. On another note I did sell an older cj5 to a guy that took it into a river and then allways had electrical probs with it till it " got stolen and was never found":huh:
Good luck with your new project !!
Yea, it does take some work to dry it all out. I’ve had fans and heaters on it all week and it is all dried out but a little bit of moisture coming from the lowest point in the drivers’ side floor pans. Judging from the drying process I observed all week (I’m kinda of an expert now) I expect that it will be completely dried out by morning or shortly after.
I’m sure glad I didn’t listen to your advice. :laugh3: Putting down heat and wind is much less work than what you’ve done!
