El Sheetbox
El Junky
sorry terrance i actually might know another guy that might want it.
also, allen, did you say you where running the tranny lines through the stock radiator? that could be it. I would bypass that at once and get an aux tranny cooler instead.
I wonder if it was leaking because it was overfilled?
water could be from that other tranny ? didn't you guys say it water in it? Did you say you put your old torque converter back on? maybe that was the culprit?
I ran it to an aux cooler... I would say it was leaking from being overfilled and from wheeling it had the line pressure high that it just pushed it out that pump seal... Cuz now I can't get it to leak at all with proper level... I assume the water was from the trans... The radiator doesn't seem to be crack cuz it's not leaking coolant out of the tranny spot on the radiator...
Yes old tc went back in cuz the one I got was rusted on the inside... Think my tc is cracked and only leaks under heavy pressure?
Re: El Junky
I consider trying to find a decent TC . youll be king at pulling off AW4s after all of this
El Junky
Well just wheeled it alone up Deloris and no leaky... Ill check level once I get home... I can't imagine I overfilled it by 2-3 quarts... It def had water in it and not sure where that came from... The rad is still not leaking anything out the trans cooler ports...
Re: El Junky
weird
El Junky
So I drive it today everywhere an got home to check the level... It's above the ok line now... So I drained it again to look at the fluid and it looks like there is maybe a little more water or something in it... So topped it back off with only 1qt this time and its at the very bottom of ok right above add... So ill leave it there and drive it and see what happens
El Junky
Went to moonrocks today to watch others today an took my jeep... Still no issues but didn't wheel to hard either... I need to dial it in before next Thursday for rubicon...
El Junky
Well everything seems fine went out to see if tranny would leak again and no luck so I should be good for con on Thursday...
El Junky
Good to hear.. is that Sean's rig.. Tell him I said What's up and thanks again for wheeling with us!!
Yea that's Sean! I also found out that my steering box broke today... Was getting a noise when I would turn and fingered it out today... The rear ear that you bolt the box it ripped off the case so I only had the front 2 bolts holding it which made for a lot of play even with a brace... So today I replaced it with a stock box which is gonna suck next weekend at the con since stock box sucks for steering... When I get back ima just get hydro on it...
Re: El Junky
i was thinking that too terrance, that musta been sean. I guess im building a hp44 now...
