El Junky Dos
You can use a offset tb bracket to put it infront of the coil bucket if you staying with coils or a centered tb bracket if going coilovers.
on top of the diff? always looks like it will bind at full driver side compression. pass drop has crossed my mind I'd like to see it done.. Allen
I was also thinking of doing it on the other side to keep it easy...
As in have the axle side panhard bracket on the drivers side? You would have to go full hydro if that's what you're talking about. Otherwise the draglink and panhard will bind/fight eachother
This is the fzj80 im running in the front of my rig. 60 center section will be a little taller but he shouldnt have a issue. With the chevy 60 he could bolt and weld a plate to burn a tb bracket to where the leaf would be mounted to.
Worked on el junky one then found time to grind all the undercoating off the unibody for stiffeners... Then I took it out on some dirt roads and jumped it :) this thing is a blast in stock form! Lol
that thing must be a blast to drive
Little progress... Got some stiffener metal and test fit... Gonna drop off in te am for a buddy to make some holes for plug welds...
already on your way to el junky 3 I see...
:clap:Wow, I was offline for a few days and there is another Eljunky thread! LOL had to read through the whole thing to catch up.:clap:
I like the giant bottle jack alot. good call on the 220.
then you can build some legs from the frame to the roll cage plates
The jack help me form the steel to fit tight! Haha ya I was gonna add legs to the stiffeners... Not sure what I wanna do fr sliders yet... Was thinking tube sliders so it flows with the rest of what I'm doing;)
Got a 30 moving permit so I can drive it... Getting tube tonight to start sliders and cage work
Haven't done much.... I "finish" welded the stiffeners on... Got some tube to build sliders out of yesterday and some tube to do some things to the cage...
