I've seen some people cram various types of OE electric fans to replace the mechanical one. What about using another XJ electrical fan (the later type)? Would it move comparable CFM of air as the mechanical fan?
Lots of people have tried the cramming dual electric fans instead of mechanical job. Most of those who've doen it end up going back to stock mechanical fan (with new clutch) and later model OEM electric fan, it just works best that way.
I run two fans in front of the radiator and two in the engine compartment. it never gets hot unless i let it. i did this because of my frequent desert trips. leaving san diego going up the grade @ 85 my jeep use to get to about 230 or so degrees. now it barely gets to 210 and that includes long trips throught the dunes at 100 degree weather.
well if stock ones will not work due to air flow restrictions what about 2 slim flex fans? they seam to replace cluch fans on v8s alot. they also sell them to replace the fans in TJs so why not on an xj?
