MaxxXJ
- Bakersfield CA
yanno if it was me looking for lift... i'd do your lift shackles you have there, then measure the front fender height, then the rear and when i saw the rear sagged more than the front by X amount of inches, i'd go down and buy a set of blocks in that amount... if blocks were so bad for LIFT then people wouldnt do it to every lifted truck i've ever seen on the road. the only drawback to blocks is that you wont get the articulation like you would if you had just re-arched your springs or bought new lifted leaf packs. and blocks are like 20-30 dollars at autozone =).
i actually thought about doing blocks to cure my sagging stock leafs for a period of time until i could afford the 3" BDS lift hit
