learjets said:I would like to install 31-10.50x15 on the Jeep.
99 % on road.
I've got 235/75-15 Kelly SUV right now.
Looking spending the least - without regretting it, and having to redo later.
The Daystar kit is actually designed to give you one inch -- that's what the shackles produce. The front coil spacer is 1-3/4" but the intent is to replace the stock spring isolator rather than retain it with the spacer, which reduces that 1-3/4" by the thickness of the stock isolator.BeJay1981 said:The Daystar kit is nice but it will give you 1.75 inches in the front and MAYBE 1.25 in the back with the shackles. You will be able to fit a 30 x 9.5 and it will look nice.
