Rob707
- sacramento
used hp dana30 4.56's with carrier out of my xj. no setup needed but it will need spiders or locker installed into carrier..... $100.00
Hmmmm I think I might want this one too. So I could just throw an Aussie or something in it and put it under my Jeep? No backlash and all that crap with the gears?
add whatever you want into the carrier, install it and its ready to go...
Uh, ya right.![]()
Jes is right. The no set-up needed thing is total bullshit. Buying used gears is always a crapshoot, but to say they will drop right in is ridiculous. I would save your money and buy a new set considering you WILL need to set them up properly.
Uh, ya right.![]()
reaLLY??? ive blown up ring & pinions, went to the junkyard pulled another set, installed them, checked everything and the setup was fine.... in the last 17 years ive been wheeling, ive built plenty of thirds so im not talking out of my ass about shit......
.So, do you blow up a ring and pinion every time you go out?
Might be because of the install?
A Dana is not an Eaton or Ford 9. You don't get a full third member from one axle and pop it in another.
Note to everybody but Rob707, don't follow this advise. This advise is bad and will kill baby puppies.
