Kestrada5
- Thousand Oaks CA
Hey so I have a 97 xj with a HP Dana 30 upfront and I believe it has a shitty pinion bearing...considering the horrible noises it makes. Anyways I went and got a Dana 30 from under a Comanchee yesterday but it has the factory vacuum disconnect. I was wondering if I could entirely switch the carrier and pinion(including the shim stacks)from the comanchee axel and just swap it into my existing axel under my jeep. Ive heard from a couple buddies that it wouldn’t work and the housings are a little bit different, or some other issues. Some said it would work because they’re the same. I’m asking for a more professional answer rather than hearsay. Thank you.
