dana 30 ring gear torque specs
88XJ-AK
North Pole AK
I have a 88XJ I am looking for the specs on the ring gear and caps, I have searched and found other axles just not the 30, other sites refer to different years have different size bolts with different torque specs, either 55ftlbs or 70-90ftlbs but know one new the year cut off or bolt size. Does anyone know what the XJ uses?
Thanks
Donald
FSM 90:
Set-to:
Ring gear to case bolts: 55 ft lbs.
Differential bearing cap bolts: 57 ft lbs.
Service re-torque:
Ring gear to case bolts: 45 to 65 ft lbs.
Differential bearing cap bolts: 52 to 67 ft lbs.
