1990XJ4x4
NAXJA Member #1158
- Louisville, KY
Ok, well this install just got a little more complicated.
I'm working on an 03 TJ w/ a dana 30 up front and 3.73s
took the axle shafts out, knocked the roll pin out that holds the cross shaft in
When I go to take out the cross shaft out, it hits the ring gear leading me to believe that not only are we going to have to remove the carrier, but also unbolt the ring gear. :doh:
Any tips on removing the carrier and ring gear. Am I going to need any special tools to set things back up, or will it just go back together.
I need to get this together tonight so we can wheel tommorow morning.
I do not have the tools here to go about resetting any backlash etc.
