MoparManiac
- Amherst, NH
I've always wondered why no one has tried using a load bolt yet. Grab a kit from that Jantz guy on Pirate and see how it holds up on something like sunburned's axle.
right.
and I'm not saying that the 30 is a bad axle... my advice is simply spend less on it than I did.
building a 30 for 33"s cost a hell of a lot less than building it for 35"s and the ability of the jeep doesn't suffer much.
Before you get too committed, open up excel and run a spreadsheet on costs to build a 30 , a 44, and a 60. you will see that in the long run, the real differences will only be the initial costs of the housing , new front rims and brackets between the 30 and the 44, and between the 44 (say a 65 WMS to WMS hp44 use more backspacing so you don't need to narrow it) and the 60 will be narrowing the front on side and shortening one front shaft and maybe/probably get stuck going coil overs on the 60 too due to lack of room for coil buckets.I am assuming you will be going brakes, ball joints, U joints, shafts, bearings, spindles, hubs, lockouts etc on all axles . There are some potential cost savings on the 60 too. run a 35 spline lunch box and 35 spline stock shafts and U joints.
An XJ just doesn't have enough clearance with 32-33" tires when wheeling the pointy rocks at Rausch Creek and the like.
$3k ..... that's less than some people have put into the D30s in this thread.
Not true. Not even close to true.
A mildly built D30 with 33s will reliably take you through 95% of the trails at Rausch Creek. Which is why its such an awesome little axle.
don't forget the cost of 5 new wheels, and either new rear axle shafts or a whole new rear end, depending if you go 5x5.5 or 8 lug.
I found my hp44 with good ball joint, brakes, rotors and warn premium hubs geared 4.10 to match the rear 60 I already had for $150. Wheels were $130 and $100 in brackets. Up and running for $400. Broke a long side shaft and bought a set of Yukon shafts for $500. For less than the cost of rcv's I have a strong setup that cost me less than I put in my 30 that always seemed to fail at the worst time.
Define built.
If you built your 30 the way you built your 44, that makes total sense.
HP60 - $200
5.38 gears/install kit/carrier - $240
Ten Factory chromos (custom length long side) - $700
Ruffstuff cover - $100
Lockright/KP rebuilds/bearings & seals/lubelocker - $750
NWF high steer arms - $350
Truss/3 link brackets/knuckle plating material - $40
-$2380
C&C 14b - $85
Ruffstuff cover/disc brackets/pinion guard - $180
Bearings & seals - $60
Shaved 5.38's gears/install kit - $450
UBE's/truss/shave job/orb of traction materials - $40
-$815
~$3200, guess I was a little off. I coulda saved money by re-using the wheel bearings and some of the other seals but I just ended up doing everything, coulda got cheaper steering arms and welded the front too. Eventually I wanna get a ARB for the 14b so that'll be more money.
I estimate the cost of my 30 at about $6k... If I had paid retail, and that includes gear install labor
You did pretty well...
Add 1000$ to anyone in SoCal looking for an HP60...
6K?
what, did you tip everybody 100% and ship the parts through China and back?
or are you estimating the way i estimate horsepower
so that's not the actual number? what do you actually have in your D30..
