- Bakersfield, CA
Has anyone run across high steer for ball joint D60 knuckles other than going with the Currie setup? Currie sells knuckles that are machined for high steer arms and they come with the arms, but what do you have to do to get high steer on your own ball joint D60 stuff?
We found a couple of complete D50's out of Excursion's at a real good price ($500). I wouldn't use the center section, but I would consider using the outers on a D44 center section if I can figure out the high steer. If I have to get Currie knuckles then it defeats the cost savings of getting the D50. Of course, this might all be moot for me since I don't think I can use my 15" rims with the stock brakes, so I need to see what might be able to be worked out there, too. Tim has to get new rims anyway, so he can use the stock brakes, but we have to figure out the high steer.
