- Hartsville, South Carolina
Shares the part number as what? I don't believe they are the same MC.
They are not the same I think my IE did something flaky. Went to O'really's and spent $64.99 for a brand spanking new one. I figured that was a decent price and worth it to know I can stop the jeep when I go to Harlan next month. :gee:
Yes, I did mean Durango master. I think it has a larger 1 1/8" bore. If you use a booster like my '95. The booster and Durango master should be a bolt on with no mods to rod length. The '97 up master has a longer rod that attaches the pedal assly. I think this is what you discovered already. Would you have a long enough stud to run a spacer between the booster and firewall? That would probably be the easy fix if you wanted to stay with the '97 booster.
Pirate THREAD on Master/ booster combos.
Ugh, I hate Pirate. I should be able to space it out without a problem. Picked up some washers at lunch. Lennie, aforementioned mechanic suggested using a piece of plate. Seems like there is a seal there that keep water out of the booster and out of the cab. :dunno:
Worth noting... .25" may not seem like much, but that results in a 56% increase in fluid flow for the same pedal movement.
Interesting that the WJ and 97 XJ MCs have the same diameter and fittings but aren't the same part number - do they bolt up the same way? I know my 94-down booster/MC had four mounting bolts while the WJ and apparently 97-up (95-up? I don't remember what they look like) XJ booster/MC have 2 mounting bolts for the MC.
The '97 booster bolts up to the same as the '94. Mine slide right in with some tweaking of the bracket on the inside of the body. I noticed the Dodge has a different fitting for the line then the older xj's. Mine is an double flare IIRC and this is a bubble flare? Anyone know off hand what the proportioning valve is? I think its a double flare. So I grabbed some line while I was there. I did forget fluid though. LOL! I think one of the boxes of fluid in the back has one in it though. Just need to remember to replace it before Harlan. :wierd:
On a side note I just noticed the multi quote button. Much essayer then copy paste. :wierd: :roll:
