D30, Shafts, Day saver!
slcpunk74
UTAH
I have a housing that was from my 97 xj so it is a high pinion with 3.55s(open)$30 no shafts or knuckles
Pair of 297 d30 shafts from my old housing $50
Knuckles and calipers from a tj front axle $15
Xj Hub bearing with a 2wd stub shaft so if you break a shaft on the trail you can remove it and use this to get you home. Could save your day! Easy to keep in your vehicle everyday as compared to a set of shafts$30
Dynomax muffler from the xj cat back system. I used it for maybe a week at most and then cut it off. 2.25" in/out $20
Call/txt anytime but leave a message
Chadwick
801six 9458 two 5
