CAJJ93XJ
- Roseville, CA
Uhhhh..... i'd leave it because most people specifically truss it in order to 4 link it. gives you a mounting location for the upper links above the pumpkin. Maybe just cut the spring perches off.
I don't know a lot about jeeps but I can tell you that the axle housing warped a little when the truss was welded on unless extraordinary measures were taken during the process. I would torch off all but 1/2" or so and do the rest with the grinder. Housings aren't perfect and the parts that go inside are designed so that it's not a huge problem.
Agreed....... unless the OP is entering his pile in a show and shine ..... who gives a *****![]()
I guess you could weld a truss to the bottom to keep it from warping too much, then cut the top one off, then weld the new one up top, then cut the bottom one off ? Too much work and it still might not work?
Make a new pretty one, and add it on top/over of the original. Super double awesome truss.
Huh ? The parts that go in a axle housing are designed to work a specific way. Not to be sloppy enough to work in warped housings. If that was the case bending a shaft wouldn't cause leaks and other issues with your axle. Unless I'm misunderstanding you or something.
True but manufacturing tolerances on car part that large allow for some variation over it's length. If there is .005" of play in the spline, I would imagine over the 3' length of one side of a housing could be 1/8" out without it causing an issue. I wouldn't be a bit surprised if a 3"X 3/8" wall tube with two full length stringers running it's length, both on one side of the tube would cause 1/8" of warp at least. I am welding a truss on an axle in the next couple of days and Ill see if it moves or not. I think it will.
14bolts are like free axles. Why not just find a stock unit?
