RWKHausSupply
- yorba linda, Cali
Currie 9+ Heavy Duty axle with your desired gear ratio and with many options available.
This is a complete kit. The 3rd member is setup & ready to bolt in, the axle shafts are ready to slide in, and spring perches ready to be set for your exact pinion angle.
Click here to go to site / item
Features the 9-Plus heavy duty housing and 31 spline performance axle package built to the stock overall width and pinion offset specs. of the vehicle. Heavy duty 2 1/4” wide leaf spring pads and XJ specific shock mounts are included with the unit and must be set to spec. by the customer and welded at time of installation. Housing includes all 3rd. member studs installed and the Torino style late model large bearing housing ends. Axles include the 5 on 4 ½” and 5 on 5 ½” wheel bolt patterns drilled in them, and wheel studs installed in the stock 5 on 4 ½” pattern, ¼” thick heavy duty bearing retainer plates, and tapered Timken style wheel bearings pressed on. This unit will allow for the use of many brake kits, including the 11” drum brakes, 11” Ford Explorer disc brakes, or Wilwood disc brakes. Unit is 60.625" wide (Stock).
Then you get one of the strongest 9" Assemblies you can buy. All Yukon heavy duty parts. These are ran in numerous off road competition rigs around the world.
Yukon Extra HD 3.062" Nodular Iron Dropout
Nodular Daytona Style Pinion Support
Yukon high performance gear set
Yukon Master kit used in assembly all Timken bearings
Yukon forged 1310 yoke
Yukon locker of choice
Above with Grizzly mechanical locker - $2399
Above with Zip air locker - $2699
Add:
Explorer disc brake kit(complete w soft lines) + $470
REM finish (polished) gear set (requires no break in, cooler running) + $45
This is by far, stronger than any of the Ford 8.8 or XJ Dana 44 swaps out there. And all NEW. No past owner issues.
Robert
RWK Haus Supply
[email protected]
714-875-2414 (call or text)
Add:
Robert
RWK Haus Supply
[email protected]
