SleeperXJ
- Valencia, CA
1999 XJ, 4.0, Automatic, NP231, Dana 30/44, 416k. Clean title, passed smog prior to current registration.
Blue color, charcoal interior. Fair body, clear coat is flacked off and some minor rust on roof, new windshield. Stock AW4 automatic transmission and Factory aux trans cooler (part of up country option). Interior in fair condition with newer head liner. Pioneer radio, Working Heater and Cold A/C, Power windows working, Power locks not working, factory roof racks.
Upgrades:
New radiator installed last summer and new fuel pump
Mean Green Starter and Mean Green 200A Alternator
Coldwater cylinder head (around 3 years old)
K/N cold air intake
4 hole upgrade injectors
Hesco High Flow Thermostat housing
NP231 Transfer case with Advance adapters slip yoke eliminator
Tom woods rear drive shaft
TRI-COUNTY GEAR Dana 44 rear axle 30 spline chromo axles, 4.10 gears with ARB air locker
Heavy duty Trac-bar HD track bar
OME 2" rear leaf springs with JKS shackles for ~3 inch lift (with tire carrier and spare mounted).
Bilstien shocks front and rear
Extended braided brake lines front and rear
Front high pinion Dana 30, 4.10 gears with ARB air locker (30 spline)
Super 30 axles 30 spline inner/27 spline outers
2" OME front springs with JKS ACOS spacers nets ~3.5 inch lift
BLACK MAGIC replacement front brake calipers
ARB CKSA12 On-board air kit
C-ROK Cherokee XJ Steering Box Spacer Plate
Currie Currectlync Heavy Duty Tie Rod/Drag link system
JKS upper & lower adjustable control arms
JKS sway bar disconnects
ARB Front & Rear diff covers
C-ROK Tire Carrier and Rear Bumper
AJ's Offroad Rock Sliders.
Also includes:
New 4" OME HD leaf springs and degree shims and OME934 ZJ HD coils from DPG
TnT XJ Frame Stiffeners ready for install.
The down side:
416k miles: engine is still strong but needs rebuild (or stroker!).
Ball joints: need to be replaced.
BFG 33x10.5R15 AT tires: some life left but…
Asking 5000.00 OBO! Jeep is available in Santa Clarita Valley or San Fernando Valley.
I'll post up some pictures tomorrow
Upgrades:
K/N cold air intake
Also includes:
The down side:
