Ben824
- Woodstock, GA
Ok so here is my review of the 2 row Champion all aluminum radiator. This review should be helpful to those that have been on the fence between the CSF 3 row and the Champion 2 or 3 row units or the AE 3 row unit as I am replacing a CSF 3 row unit with a Champion 2 row. If you are new to wrenching on your Jeep and absolutely terrified of the thought of modification over straight bolt in then go with the CSF unit as it is 100% bolt in and you should get atleast 4-5 years out of the radiator (I got 7 out of mine). The Champion 2 row dropped in place just fine and I had to do the MINOR transmission line modifications that others had to do but as long as you have a few hose clamps, about 7 inches of fuel hose, a dremel, and a hammer (mini sledge in my case), then you will be able to tackle this just fine. This is an easy install as long as you are prepared.
Now I want to start by saying the CSF was a good unit for the years that I had it it kept the temperatures down for a long time but it still went bad and sooner that I wanted for the over $200 that I spent on it years ago. The CSF unit, compared to stock, is an upgrade in that it is all metal and has 3 rows. But it is still pressed together and made of a metal that will corrode and fail. It also has a plastic drain plug on the side.
The Champion is a fully welded all aluminum unit with a metal drain plug that I had shipped to my door for $174 total! I feel confident in saying that I don't expect to replace this thing ever or atleast far past 7 years.
Here is the CSF unit that I removed compared to the Champion unit.
Here are the reasons I had to replace the CSF unit.
This is where is began to leak from. Notice the plastic drain plug.
Paint chipping off didn't look too good either.
Now here are some size comparisons. This is where is gets interesting.
This is the CSF 3 row unit core thickness.
This is the Champion 2 row unit core thickness.
The Cores of both units are virtually the exact same thickness. So the surface area of the rows are the same despite the champion being 2 rows and the CSF being 3 rows. The CSF really cannot cool any better since it does not spread the fluid out over a wider area to get more cooling than the Champion 2 row does.
So lets recap real quick The Champion 2 row offers the same surface area for cooling as the CSF, costs less than the CSF, is made from higher quality aluminum, and is made to a higher quality standard being fully welded. Seems like a no brainer to me.
Ok so here is some info on what I did during my install. This is NOT a step by step install, simply just a review of notable things to point out that anyone will run into during the install of a Champion 2 row radiator.
Here are some of the upper radiator support isolators that will need to be transferred to the Champion radiator.
These are the support brackets for the A/C condenser. I didn't take pics of both since you can get the idea from the one and you can see the other side in the pictures above.
The Champion radiator already has tabs welded to it to support the A/C condenser but I figured I would transfer the original brackets over if I could just to have extra support. The holes in the brackets did not match up with any of the hole on the Champion radiator so I ditched them since I did not need them anymore anyways.
I knew I would need to modify the transmission lines slightly in order to get this to work so here is what I did to the factory quick connect elbow for the lower supply line.
I cut the elbow where it would normally connect to the radiator. The tools of choice for this task was a dremel and a pair of vice grip pliers to hold the elbow.
