RockControlXJ
- The Woodlands, Tx
Over the past couple years i've worked on quite a few trail ready XJ's/Zj's. I've seen a lot of good mods and a lot of S@#t. One of the area's that has always seemed weak on a cherokee is where the bumpers mount. When it came time for my own personal Driver/Beater i decided to go all out and address a few things
1. The bumper bolts to sheetmetal. NO GOOD
2. Steering boxes are bolted to sheetmetal. NOT GONNA FLY
3. There is nowhere strong enough to attach recovery equip on the front (or rear) of an XJ.
Heres what i decided to do,
Get rid of the front crossmember, its pure crap
I used a spot weld bit to remove the member, make sure to leave somthing straight to attach the new member to. I used the old spot weld locations.
grind your spot welds flat and fit some material to replace what you've hacked. A 2"x5" box will fall right in, but i decided to make mine more complicated so i could fit a winch in without killing my approach angle.
Use at least .25" wall box tube. Remember you will be welding a bumper, winch mount, and D-rings to this, not to mention its holding the front of the truck together.
I also strapped the top and bottom of the crossmember with some 1/8" plate
Now i wanted my steering box to be stronger as well. What better way than to tie it into a box tube crossmember with some 1/4" plate
now since the stock radiator mounts are part of the original crossmember, you'll have to fabricate those too. Heres my solution
Finish weld everything and bolt the front of your truck together and it'll look somthing like this
The front crossmember is now a solid point to attach a real bumper.
