correct part numbers for tie rod ends
Axle
Midwest USA
Hello-
I am trying to service the tie rods on my '89 XJ. My parts house got me the wrong end for connecting the pitman to the sleeve to the long end that also catches the stabilizer and "center" tie rod end...and they can't seem to find a number for what I need ?!? Does anyone have a link to or know the correct names and Jeep part numbers for each of these ends? I have a new long end for the passenger side knuckle which fit the old sleeve. I really need the pitman-to-sleeve tie rod end which appears to be about 20mm at the threads versus the smaller ones at the center postition and the driver's knuckle which look like 17mm or so.
Thanks for the help!
Here's a list of part numbers from my 89-90 catalogue. Sorry about the format, but I hope it helps. These are for the Cherokee XJ.
1 5200 0608 END, Tie Rod
2 5200 0988 COVER, Tie Rod End
3 J027 1287 FITTING
4 5200 0596 TUBE
5 5200 0599 END, Tie Rod
6 5200 0598 END, Tie Rod
7 5200 1736 TUBE
8 5200 0601 END, Tie Rod
9 J027 4428 NUT
10 J010 3375 PIN, Cotter
11 ARM, Pitman
5200 0615 w/Power Steering
5200 0616 w/o Power Steering ***
12 S010 3336 WASHER
13 J320 0501 NUT
14 J323 6097 DAMPER
15 J012 1224 PIN, Cotter
16 1150 5098 BOLT
17 1150 2813 NUT
