cooling idea..........old news??
Rockhound
Pensacola, FL
i was replacing my mounts for my engine today and i strted thinking about replacing all my cooling components next month. i'm sure this has been thought of before and there may even be a kit if its practical. i'm thinking of yanking my mechanical fan and replacing it with a dual electric fan setup. theoretically that should regain a little power and help keep the engine much cooler. gimmie your thoughts.
Rockhound
Don't waste your time with the electric fan idea. It's been tried several times by myself and others. The mechanical fan works better than any electric I know of. If you don't have an aux fan on the driver side, installing one yould be a great help.
mattk
I've been thinking the same thing, I may give a shot and install some hood vents to help disipate the heat.
Note: I've got a 3 core radiator and wouldn't consider it with a stock unit.
I'm pretty happy with my electic conversion too. I stuck in a GDI 3 core radiator, new H20 pump, and squeezed an imperial 12 inch fan. I also got the imperial wiring harness that will controll both the new primary fan and the aux fan simultaneously.
The rig warms up much faster, and the needle is always below 210, right at 210 at long idle with AC on max.
I also suck in a gigantic transmission cooler (WAY overkill, but it rocks), bypassing the tank coolers, which might have helped out a bit.
Total cost (parts bought over a period of time)
12 inch imperial fan (autozone) - 70 dollars
Dual thermostatic/ac override wiring harness - 20 dollars
New H20 pump (free w warranty)- usually 30 dollars
assorted wiring bits and pieces - 5 dollars
24,000 gvw tranny cooler - 40 dollars
barbed connectors for cooler - 5 dollars
GDI 3 core radiator - 100 dollars
I probably should have done my hoses but it wasn't on my mind at the time. Pretty soon ill be sticking in some hood vent too, Ill let you know how it goes. As for HP gains, I dunno. I guess a little seat of the pants feeling at wide open throttle, like at 4000+ rpms, but no real world gains.
The main 2 reasons I wanted to do it was
A)the option to turn off the fans when crossing deep water/mud to prevent sucking gunk into the radiator, also preventing the mechanical fan from "swimming" the engine forward into the the rad.
B) With less resistance from the fan, the engine works less hard. Combined with the tranny cooler, I hope this extends the life of my drivechain.
my 2cents
Flex-a-lite makes a Dual 10" setup with shroud that darn near fits the XJ radiator perfectly (height wise, leave about 5" on the side)
I run it. it blows like a 70s Ron Jeremy Flick. Very good flow, but I can watch my voltage drop when I kick it on.
Fan setup is like $160 though
\\hoot
You will notice that everyone who likes eh dual fan setup does not live in a hot climate....the setup is worthless for hot climates and heavy towing or other heavy use.....Many of us ahve done real world testing on it in AZ..CA...NM...UTAH and plainly spoken the fans just dont pull enough air...I even went to triple electric fans here is my write up on the fiasco
http://xjnation2.homestead.com/thegreatelectricfanmyth.html
I really think yo can spend your money in other better ways.
I live in FL. I didn't say the electrics don't work. They just don't work as well. I have the three core too.
mattk
I built mine in AZ, and now reside in NM.
With the engine I have I dont have any other options that will fit.
But I run a tad hot sometimes. That is more due to the Hi Compressions and .060 bored SBC
Hot climates and electric fans suck bad. Bring your rigs down to Texas this August and sit in Dallas/Ft. Worth rush hour traffic with the A/C on and I guarantee that the electic fans will fail. Maybe there are special occaisions on specific XJs But as a whole they will not pass the southern heat test.
By the way, I ran the 3-row GDI and Flexalite 110 on mine.
Should have spent the money on a new mech. fan.
$.02
Mike
well alright. thanks guys. verdict..............in Pensacola, FL, i'll stick with my stocker setup. does anyone have a particular system setup then. i plan to get the GDI, but is there a specific aux. fan that works better than the factory? any other cooling system components? TIA
Rockhound
Not sure what year you have, but if its an older one I would replace the aux. fan with a later model aux. fan. Better design and better flow. The old one has fat straight blades, and the newer one has more narrow curved blades. FYI
Mike
Its funny listening to all of this. my clutch fanis pretty much useless and i still have the original old style aux fan and even in the hotest days (110plus) my temp guage never goes over 210. I've been looking at eltrice fans and some of them say they are good for up to a 5.8l by its self. so its interesting to hear they don't work well.
Just speaking from expierence REDXJ. I know everyone has an opinion as well as different results.
LOL, Aint that the truth. Just swapped in a new D30 and WHOA!!!! Time to go to the alignment shop. Feel free to flame because YES i can align it and reset the steering wheel straight myself, BUT Im lazy and dont feel like doing it:D
Mike
Does anyone know the CFM rating of the stock mechanical fan? Granted it would be dependant on the engine RPM but just wondering how much air it actually pulls. I've tried a 1,250 CFM electric similar to the Flexalite 120 and wasn't really impressed with it. It did "ok" but on really hot days under load it wasn't keeping up like I thought it should.
One idea I was thinking about since I removed my AC condensor was to move the radiator forward a bit. Looks like I could go 1-1.5" forward, maybe a little more. Then I could do a little trimming and get some space in there to fit the Perma-Cool 14" electric fan that is rated at 2950 cfm. I like electrics for the ability to turn it off when crossing deep water, especially those thick mudholes. Just a thought.
The problem may be that there is too much of a gap around the housing/shroud Aand the radiator. My new electric is only 12inches, and the housing is almost exactly as tall as the new radiator I put in. As such, almost ALL of the air it pulls in (only 850cfm) is being pulled through the radiator itself instead of just pulling air from around the shroud. I dont see how you could get a 14 incher in the compartment without making a custom shroud.
