- Golden, CO
HOLY COW!!!!!!!!!!!!! :shocked: :wow:It usually takes 4 months before it's blocked on me.
Das is not normal!
Das is not normal!
Older post but not really much info on this wix mount on the net. Anyone have flow problems with the ports being so small? The fitting for the filter is maybe 3/16 and the port drilled in the body of the mount is about 1/4 just by eye. Thats one hell of a flow restriction to me. The filter fitting has the meat to match the other and then some. Drilling the mount bigger could be a problem.
Any problems with the inline trans filter? I don't care for the idea of cutting a steel line and replacing a section (two technically I guess) of it with rubber hose and clamps. Running PSI is around 80-90 and can get up to 200PSI at higher engine rpms. Seems like it would be a weak link for a possible leak. I can't believe two dinky little hose clamps would last for a long time.
Bull!
Transmission cooling lines might get to 50PSI, max.
Fluids flow in the path of least resistance. A open hose would favor most if not all the flow vs being forced through a filer. Even more so when the heater circuit is a very low pressure bypass circuit. Hard to think of the filter in a bypass setup on the cooler line realy helping at all.
Yes, but do they have an internal bypass valve so they don't stop flow if clogged?
