papa102498 said:
I just installed a Rustys 3 inch on my 2000 limited. I had put R.E. adjustable control arms on a few months ago and they are still at O.E.M. length, any suggestions on proper length for both uppers and lowers for the new springs. It does have a serious death wobble right now but I ordered a pitman arm and adjustable trac bar from Off Road Outfitters and hopefully with these and an alignment it will drive like it should.
pitman arm will just add bump-steer into the mix. it will decrease the angle of the draglink without doing anything to the angle of the trackbar, when they should be parallel.
Here's a table of CA lengths depending on the amount of lift you have:
Lift......................LCA............./............UCA
********Decimal**Fraction**Decimal**Fraction
Stock........15.75.......15 ¾........15.00.......15
2”.............15.92.......16............14.88.......15
3”.............16.09.......16............14.92.......15
4”.............16.33.......16 3/8......15.03.......15
4.5”..........16.47.......16 ½........15.11.......15
5”.............16.62.......16 5/8......15.21.......15 ¼
6”.............16.97.......17............15.44.......15 ½
7”.............17.36.......17 3/8......15.74.......15 ¾
8”.............17.81.......17 ¾........16.09.......16
9”.............18.30.......18 ¼........16.50.......16 ½
10”...........18.82.......18 ¾........16.96.......17
