trippled
- colorado springs, co
Re: The Colorado BS thread
That's what I did for mine. Used the factory filler neck and built a box around it and a ring for the outside. Oriellys had some good gates flexible fuel filler hose that worked perfect for hooking it up to the tank.
Got windows again can stop tarping the Jeep ...I probably should have held off on buying the Lexan since the home depot only had a big sheet of uv resistant in .093 and I think the front door windows would have been better in .125-.188 since they slide up and down .I think.I am going to do the rest of the windows in Lexan as I break them . It is pretty hard to scratch from what I can see while cutting it and can cut out for a gas filler neck .
