jeepnuts311
- Atlanta, Georgia
Hey all,
Just swapped my SYE kit from my old transfer case to the new transfer case. The old case was a 21 spline unit and the new one was 23
the swap was very easy, basically split the two cases in half, then put back together. onnly two mod i had to do to the new case was
A: cut the shift rail 1" shorter (typical for the AA kit)
B: swap the cable speedo out for the new electronic sender
after the install, there is no speed signal. it is throwing the CEL for code 15 which is pretty obvious
But what i am asking is what is the most likely cause for this?
Info yall might want:
the tranny, and t-case are from a '93 XJ, swapped into a 2wd '94 XJ
the speedo gears were both orange (same ratios 3.55)
sender is plugged in
thanks in advance
-Tim
thanks in advance
-Tim
