Cleaning my garage, help me!
bmikes
portland or
Just want this stuff gone. The metal stuff will probably be going to scrap at the end of the week if it doesn't get picked up by someone.
Make an offer
Not willing to ship
Front and rear seat belts plus hardware out of my 93 2 door xj. $40
Shift boot out of a 93 5 speed free
Axle brackets for lcas, for a d30 I believe $20
Electric motor 1/3 hp, 110 volt, $10
Only one latch for a yj hood, free
Factory tow hooks $100
2" shackle mounts to go in trailer hitch receiver $5 each
12v cigarette lighter Heater & light $5
5 on 4.5 bolt pattern plate 1/4" $15
Electric fan from 93 xj $20
Portable drill, two batteries, charger. Makita 14.4 volt. $20
Rc car battery charger $5 (prophet sport II)
load securing/tow straps 30' $15 each.
Heater fan motor from xj's. $10 ea
Hi lift, has new pin kit and $70 powder coating job, doesn't Ratchet right. Probably easy fix for someone who knows what they're doing. Needs handle $50.
I'll be adding more as the day goes on
Call or text 503 317 2655.
Thanks, Brandon.
Air tank ~5 gallons I think $20
Electrical wiring kit $5
Brand new window motor $20
Squirrel fan for under wood stove or anything else you want $500
Is the window motor for a late model cherokee?
Yeah it was for mine I believe and I ended up getting a hole new assembly. You could look up the part number just to make sure though
Huge thanks on the Makita. this thing rocks.
