- Brighton, CO
I've decided it's time to get rid of the Jeep. It has been on the hardest trails from JV to Colorado, including Utah, and Las Cruces. It is NOT ready to run as I was planning on another rebuild but I've run out of motivation. I'll sell as a complete project or individual parts. Many are band new, some are used and never installed, and some have been tested in the rig for some time. Here's the specs and prices:
87 XJ Narrowed 10" in the front and 18" rear. Triangulated front and rear 4 links, subframed, caged. 16 gal fuel cell. 5 point harnesses. Has spare fenders, header panel and unfinished narrowed hood. Here's how it currently sits:
Engine:
Accurate Power built 4.6L stroker. ~80k on it. Runs strong and was built and broken in before the low zinc oil caused cam issues.
$750
Trans:
AW4 out of a 96 XJ. 23 spline output
RCP fab manual shifter with park lock out so you can slam from D to R without worrying about hitting Park instead. New never installed.
$300
Derale Trans cooler with integrated fan p/n 16510
All fittings needed for AW4 installation (over $225 in new plumbing alone)
$250
Front Dana 60:
2002 Super Duty narrowed to 67"
Stock 35 spline inners (Long side has been cut and re-splined)
Alloy USA 35 spline outters (NEW)
Unit bearings drilled to standard 8x6.5 pattern and bored for 35 spline shafts. Rear U.B. nut pinned
Synergy Suspension 35 spline flanges (NEW)
Spicer U-joints (NEW)
Weaver's Rod Shop machined knuckles with double keyed high steer arms. Undrilled so you can set the perfect steering (NEW)
Yukon thick 4.88 gears (NEW)
Master install kit (NEW)
Stock Carrier.
$1850
Rear 60 67" WMS
Spindles bored for 35 spline shafts
BlackMax 35 spline flanges (NEW)
Branik double splined heat treated 4340 shafts (NEW)
Yukon 4.88 gears and install kit (NEW)
$1200
Performance Offroad Full Hydro steering:
3" ram, 1.5" shaft 8" travel double ended ram
Finned reservoir with filter
Howe TC pump and pulley
$750
Atlas 3:8
23 spline input with 1" XJ spacer already installed
Standard shifters
1310 CV yokes
$1750
(2) ORI STX struts
16" travel, 3 trails in the hammers. Minor scratches from mock up.
$1150
(4) 39" BFG Stickies on Raceline Monster 233 aluminum beadlocks.
The wheel are brand spankin new. 17x8.5 8x6.5 pattern 4.75" Backspacing
2 tires are 85%, 2 are 90%, there are a couple standard cuts on the lugs.
$3200
(8) 1 1/4 heims. (NEW)
$200
Premier Power Welder 170 amp alternator and Mobi Arc welder.
$500
I'm sure Ive forgotten a bunch of details. Hit me up with any questions. Thanks
-Jon
Engine:
$750
Trans:
$300
$250
Front Dana 60:
Stock Carrier.
$1850
Rear 60 67" WMS
$1200
$750
Atlas 3:8
Standard shifters
1310 CV yokes
$1750
(2) ORI STX struts
$1150
$3200
$200
$500
-Jon
