MMIXJ
- Golden, CO
Harvo said:MMIXJ - Did you have to drill a hole big enough for a screw on Coax end or did you use some other type of deal where the coax attaches to the antenna?
i soldered the wires to the mount, as i needed to first thread it up/down/through the hatch, so i bought a cable w/o an end on one side.
it wasn't exactly easy, but the finished result is very clean and the mount has proven to be very stout and out of the way...
so the hole was for the stud on the bracket and i think the cable threaded through it (sorry, it has been a while).
i'll check to see if i took any pix during the install.
