Matthew Currie
NAXJA Member #760
- Vermont, land of big clay
I still use an older version of Adaptec Easy CD creator (now Roxio) on my desktop, and it works all right, but will make bad disks from time to time, and it won't tell you the disk is bad until it is finished, whereupon it spits out an unusable coaster. The "test first" option is useless. It takes twice as long and eats the disk anyway. On my laptop, with an Iomega portable burner, I have Iomega Hotburn, and this works very well. It has never made a "coaster," and if a disk isn't good, it simply reverts to the slowest speed and toughs it out. In fact, when I first got it, it came with a defective sample disk, and I went out and bought a pack of disks that turned out to be defective. I complained to Iomega that the damn thing would only write at 1x, and they were mystified. Then I put a different brand disk in, and it worked right. The point being that the defective disks burned perfectly at 1X, while the other computer wouldn't write to them at all. I don't know if you can get a copy of Hotburn without an Iomega drive, though.
Another program I have on my laptop which works very well is something called Cakewalk Pyro, which has various options for creating music CD's from other sources, such as on-line MP3's, LP's and cassettes. I've made CD's from a number of favorite analog albums using this. It also does the burning, and includes options for data disks, and has never made a bad disk. That program cost about 40 bucks at Staples. I recommend this program highly if you need some of the signal-processing functions such as noise and click removal, or if you need to split huge wave files into tracks. It lacks some of the bells and whistles of a program like soundforge, but it's well designed and very easy to use.
