Built HP30
rockclimber
Associate
San Diego
1400$
HP 30
4.56 gears
ARB
Vanco 16” Big Brake Kit with Black Magic Pads
Warn Hub Kit with Chromoly inners and outers
CTM Ujoints
Spare Warn Chromoly Shafts with spicer joints
Spare Hub
Johnny Joint Upper housing kit
Ruffstuff Cover
Artec Truss
JCR Sway Bar Brackets
LCA skids
Shock Mounts lowered for longer shocks.
fresh Spicer Balljoints
Drivers Knuckle setup for OTK steering
Trackbar mount setup for 2” wide joint in OEM location (9/16” through hole)
Comes with a straight trackbar with Ruffstuff Heims on both ends for $100.00
the price is based on roughly 50% off or less on all the major items in the axle
Axle is still in my Jeep so if you want it give me a few days to pull it.
If you come to an an agreement with the midwesterner on the knuckles/brakes what are you looking for on the rest of it?
I've been piecing together parts for a WJ knuckle swap so a lack of knuckles isn't a huge deal for me, The ARB, hub kit, and shafts would be a healthy upgrade. I already have a trussed D30 but I could decide which housing to run after looking this over. Does the warn hub kit require warn specific shafts?
