- San Jose
For sale is a set of XJ axles that I built, wheeled for about 3 years. Drove from the Bay Area to slick rock, rubicon, deer valley, prison hill, wheeled, and drove back home. Also daily drove these axles through school. Not inclined on separating, asking 2500 for the pair of axles. Bolt them under your Cherokee and wheel.
Will sell Clayton radius arms and trail forged crossover steering heim kit (tie rod and drag link) and Clayton adjustable track bar. Photos to come...
Dana 30: 27 spline
-High pinion
-Ten factory chromoly shafts+spicer 5-760x u joints
-ARB
-Yukon 4.56 gears
-Truss
-Sleeved axle tubes
-Ten Factory outer tube seals
-Knuckle gussets
-Synergy chromoly ball joints
-Ruffstuff diff cover
-knuckles drilled for heim crossover steering
-extended brake lines
-Artec track bar bracket
8.25: 29 spline
-ARB
-Motive 4.56 gears
-ZJ disc brakes
-Ten Factory chromoly shafts
-BTF diff cover
I’ll give you guys priority over FB, just let me know. Located in San Jose
Dana 30: 27 spline
-High pinion
-ARB
-Yukon 4.56 gears
-Truss
-Sleeved axle tubes
-Knuckle gussets
8.25: 29 spline
-ARB
-Motive 4.56 gears
-ZJ disc brakes
-BTF diff cover
