Ok, I tend to agree with you on the hardness of the stock lower control arm bushing. I am interested in your mounts as well, but would like some detail about them. What is the bushing you use from? Is the rubber vulcanized to the inner metal sleeve and/or the outer metal ring? Is the rubber replaceable and not vulcanized to the parts? Since the rubber is soft according to you, will the weight of the engine cause the center metal sleeve to sag within the rubber and then slop around? Is your mount a modified mount for a different engine/car? I looked at Carquest today and see that there are a million different mounts and fully half of them would probably work in the cherokee with a little work. Give me some detail on your mount and what other avenues you tried before coming up with your current mount. Thanks, Jeff
