altrocker1
- Iowa
well the exhaust is all buttoned up...had to do a slight adjustment on the tranny cable (the bracket was bent for some reason. going to get o-rings and some new hoses in a bit.
i think the starter is what is causing the issue. i still cant get the reverse lights to come on, but the NSS is definitely working. i tested the switch wire to the starter with the nss in place and when i turned the key it metered 12V at the switch wire. out of curiosity, i pulled the power wire off the starter too and hooked it to a starter in the parts pile and it fired right off. so somewhere i have a connection not happening inside the starter. this isn't a brand new starter but it only have about 5000 miles when it was pulled. shame on me for not bench testing it. i think it will still work, i just have to figure out where the bad connection is and fix it
