Build Sheet
andrew2516
I e-mailed chrysler and asked for a build sheet and this is what it says
*A7 - Cloth Low-Back Bucket Seats
-SA - Charcoal
APCP - Center Band Two Tone Paint
ARWP - Sport Decor Group
BARP - 90 Amp Alternator
BCDP - 500 Amp Maintenance Free Battery
BGAS - Power Front Disc/Rear Drum Brakes
CACP - Low Back Bucket Seats
CBXP - Carpet/Vinyl Door Trim Panel
CDBP - Reclining Front Seats
CFMS - Rear Folding Seat
CKAS - Carpets - Floor and Cargo Area
CKNS - Cargo Compartment Carpet
CKTP - Cargo Tie Down Loops
CSAP - Spare Tire Cover
CSRS - Passenger Assist Handles
CUFP - Full Length Floor Console
DBBC - All Manual Transmissions
DDQ - 5-Speed Manual Transmission
DHNS - Command-Trac Part Time 4WD System
DJHS - Dana M30/181MM Front Axle
DMMS - 3.07 Axle Ratio
DRAS - Corporate 8.25 Rear Axle
ERH - 4.0L Power Tech I-6 Engine
GBBS - Tinted Windshield Glass
GCBS - Front Door Tinted Glass
GEDS - Tinted Rr Drs/Qtr/Liftgate Glass
GEHS - Fixed Door Vent Glass
GFA - Rear Window Defroster
GR1P - Left Remote Mirror
GS1P - Right Remote Manual Mirror
GT1P - Black Mirrors
GVAC - All Vehicles W/O Power Mirrors
HAAP - Air Conditioning
JAYP - Instrument Cluster w/Tach
JBFS - Instrument Panel Black Bezel
JCAS - 85 MPH Primary Speedometer
JHAP - Var Intermittent Windshield Wipers
JHBP - Rear Window Wiper/Washer
JJAS - Cigar Lighter
JJFS - Single Low Note Horn
KRXS - STRIPE/BADGE/MOLDING/COLOR
KSXP - STRIPE/BADGE/MOLDING/COLOR
KVXP - No description found
K2RP - SRTIPE/BADGE/MOLDING COLOR
K27P - STRIPE/BADGE/MOLDING
K3ZS - STRIPE/BADGE/MOLDING/COLOR
LAJS - Headlamps On Warning Chimes
LAPS - Shift Indicator Warning Lamp
LBCS - Glove Box Lamp
LMAS - Halogen Headlamps
MB1S - Black Front Bumper
MB5S - Black Rear Bumper
MFFS - Black Grille
MHAS - Black Windshield Moldings
MMCS - Upper Door Frame Moldings
MMGS - Belt Moldings
MMKS - Body Color Drip Trough Molding
MNAS - Black Door Handles
MUKS - Silver/Chrome Badging
MWGP - Roof Rack
NAAS - Federal Emissions
NBKS - EVAP Control System
NFAS - 20 Gallon Fuel Tank
PR4 - Flame Red Clear Coat
QX9P - Black
RAAC - All Radio Equipped Vehicles
RABS - AM/FM Radio
RCBS - 2 Speakers
RDDS - Fixed Long Mast Antenna
SBAS - Power Rack and Pinion Steering
SCGP - Leather Wrapped Steering Wheel
SFAS - Standard Duty Shock Absorbers
SGAS - Rear Shock Absorbers
SHAS - Front Stabilizer Bar
SHCS - Front and Rear Stabilizer Bars
SUAP - Tilt Steering Column
TBB - Full Size Spare Tire
TBLS - Inside Mounted Spare Tire
TRNP - P225/75R15 OWL Wrangler AT Tires
TZAP - Goodyear Brand Tires
WJ5P - 15X7.0 Full-Face Steel Wheels
WKDP - 15X7.0 Spare Wheel
WLYC - All Steel Wheels
YAAS - Build To U S Market Specifications
YEP - Manuf Statement of Origin
YGGA - 9 Additional Gallons of Gas
ZFHP - Spring - Left Front
ZFTP - Spring - Left Rear
ZTGP - Spring - Right Front
ZTSP - Spring - Right Rear
Z5BS - Payload Rating - 1800#
1AAS - U.S. Dealer Retail
142S - Zone 42-Detroit
2TEA - Customer Preferred Package 2TE
25E - Customer Preferred Package 25E
3VRA - Customer Preferred Discount
andrew2516 said:
I think i have a D35c rear, is this telling me i have a chrysler 8.25?
yeah its telling you that you have the 8.25, look at the bottom of the diff, if its got a flat lip then its the 8.25 and if its round then its the turdy5. Also do you still got the link to email crysler for a build sheet?
Any ideas? Yeah - what year is your XJ? The older ones are more likely to get erroneous build sheets. C8.25 was intro'd in '91 so that narrows things down somewhat. If you need pics, go to http://www.yuccaman.com/jeep/gear1.html#axle
Here are a few intriguing notes from your build sheet:
KVXP - No description found - that's a big red flag there
SBAS - Power Rack and Pinion Steering - Rack+pinion in an XJ?
YGGA - 9 Additional Gallons of Gas - Ummm...where?
I'm guessing that you have a pre-Chrysler vehicle. As Yucca Man pointed out, a lot of the codes just don't make sense because Chrysler didn't do a very good job of bringing the AMC build codes into their system. It would help to know what year your XJ is.
I found my build sheet behind my drivers side front door pannel. Part of it was missing but i will look and see it any codes are the same. Mines a 93 also
