broke my driver side sway bar mount
vodomagoo
ny
The other night while driving home i lost the lower bolt from my disconnect and my driver side mount snaped at the coil. Im wondering the best way for a fix, ill get pics tommrow any ideas? my truck has about a 6.5in lift clayton long arms and 33's
Disconnect the other one and keep driving. :D
If you have a welder I would say just get a piece of steel, drill a hole in it for the disco and weld it onto the rest of the bracket. The only real tension on the bracket is upward motion when the body is pulling up on that side in a turn. Snapping it sideways shouldn't be too much of a problem with a weld.
