- Encinitas, Ca
Who's done this or know of someone who has?
When adding a sector shaft brace (similar to the pillow block bearing ala Boostwerks or Ironman's steering box brace) with a stock sway bar, you'll need to relocate the sway bar mounts which lowers the bar too much for my liking. Since a WJ sway bar has longer arms (approx 2" longer?), I'm wondering if mounting this bar forward of the stock location will be enough to clear hitting the pillow block bearing?
I've seen pics of the WJ sway bar mounted on XJ's, but none with a sector shaft support. Here's one pic of the WJ sway bar on an XJ, but it's hard to tell if there's enough space to fit a pillow block bearing on the sector shaft.
