What kind/length etc. brakelines are everyone running with their longarm setup?? I have 5.5" lift and RK longarms with the 22" RE stainless lines and they are currently my limiting straps... any ideas?
Get longer brake lines, get some actual limiting straps, or get shorter shocks and make them your limiting straps.
Edit: I had the same 22" RE brake lines and never had a problem. I used limiting straps though. You can usually straighten out the hard line a little to gain some added length.
Yes, those are TNT customs long arms with 5.5" RE springs. I had a dana44 front though....with a custom bracket kit on it. So, my springs/shocks were slightly different than someone with a stock dana30.
Do i need a brakeline bender tool to straighten the hardline or can i just do it with some pliers? Also should i bolt it down to the unibody or leave it dangling?
