I have an 89 XJ, and I'm getting rid of the ABS system. I want to go to standard power assessed. Any help out there? Don't tell me not to, as I've already started.:roll:
I don't want to be one of those that say go search, but go search. This has been discussed at length several times recently. Search "ABS". Look at my user name and find posts, you will find a lot of ABS posts. Be happy to answer any other ??? you come up with. Basicaly you can disable it electricly, or yank out everything and re-. Sky is the limit.plumb
Here is a site that will give you all the info you need to convert your brake system to the best possible situation. If you do not want to do the entire swap just take the information that you need.
