Why? Any reasoning behind your blank statement?
Well, he wants to upgrade to disc brakes. Explorers already have rear disc. Bigger 31 spline axles. Bigger pinion shaft. The only downfall is 8.8 is c-clip.
Disregard...I figured out that you meant WJ discs out back and not up front.....BTDT.....don't go there.
I grafted a set of D30 inner c's onto my front D44 and installed my WJ knuckles and brakes. Yes it worked well but the ball joints didn't hold up as well as I'd wished. The added cost and aggravation of getting the correct length shafts was a hassle as well.
I recently started fresh and installed another D44 that I narrowed and used Chevy flat-top knuckles and Ford hubs/rotors. The pattern change from 5 on 4.5 to 5 on 5.5 meant new wheels but the end result is worth it.
I run alloy shafts out back so moving the studs has all that was needed there. I simply redrilled the rotors for the new bolt pattern.
HTH
And the carrier in the 8.8 is weaker, and the tubes must be welded at the carrier to keep from spinning a tube, and it's narrower, and the internals are more expensive, and the diff is a rock-grabbing plow, and getting the e-brakes to mate to the XJ requires more work......Well, he wants to upgrade to disc brakes. Explorers already have rear disc. Bigger 31 spline axles. Bigger pinion shaft. The only downfall is 8.8 is c-clip.
Hmm...very true. I take my "blank statement" back.Disregard...I figured out that you meant WJ discs out back and not up front.....
Keep the D44, add a set of Alloy Shafts..... preferably from a supporting vendor.
IMO:
I would do a 8.8 before a D44.
reasons.
MUCH stronger tubes.
You are going to truss it anyways right? Welding all that to the thinner and smaller D44 tubes will likely bend the housing/tubes in a D44. Alot less likely in a 8.8 and you will remove the down side of the 8.8 and welding the tubes to the housing, since you will have a truss that will be welded to both tubes and the housing (if done right).
The c-clip eliminator for the 8.8 brings the width back to stock, adds chromoly axles, and removes the C-clip down side (if that really is one). And only about 100$ more then your chromoly D44 axle kit.
The disc brake do not impose any real ebake issues to a XJ, either spend the 45$ on new direct fit cables that just fit it all together like it was stock, or just do the cable mod for about 10$ that most do.
The disc brakes are already on the axle and parts are same or cheaper then a D44 for future maint.
I hope if you get a D44 you will replace the carrier with a locker or quality posi? If so then the F8.8 is only about a 50$ add, to do the same. SO a little bit of a down side but you get a stronger assembly when done.
The 8.8 uses a flange, alot better for any 'rubbing' of the yoke/flange then a yoke.
Only good side to the D44 is if you really wanted to go 35spline, you can, but then your stuck with a ARB or POSSIBLY a detroit if you can find one.
And I do agree though, Buy from a major supporting vendor if you need parts.
Lastly....he's already got a D44 from an XJ that is a direct bolt in.IMO:
reasons.
You are going to truss it anyways right? Welding all that to the thinner and smaller D44 tubes will likely bend the housing/tubes in a D44. Alot less likely in a 8.8 and you will remove the down side of the 8.8 and welding the tubes to the housing, since you will have a truss that will be welded to both tubes and the housing (if done right). If welded properly there's no worries about warping a D44.
The c-clip eliminator for the 8.8 brings the width back to stock, adds chromoly axles, and removes the C-clip down side (if that really is one). And only about 100$ more then your chromoly D44 axle kit. More parts to add to eliminate what the d44 doesn't have to begin with.
The disc brakes are already on the axle and parts are same or cheaper then a D44 for future maint. No appreciable price difference here.
The 8.8 uses a flange, alot better for any 'rubbing' of the yoke/flange then a yoke. Yes.
He wants to weld on a truss so really how much more time would it take to weld on some perches? Not much. And also someone suggested doing u-bolt eliminators so he'd have to cut the d44 perches off anyways. Bolt in the d44 though. And giver.Lastly....he's already got a D44 from an XJ that is a direct bolt in.
I'll say this, as someone who runs desert, on 33's, I wouldn't run an 8.8. Like mentioned, it's an anchor. Also, I've never been a fan of the off center rear diff, bugs the hell out of me.
You just hate all things Ford, dont you Jim? I can say we ran Compadre Truck Trail and part of the B500 course a few weeks ago with 17 Fords and not one person complained about their "anchor" or had any issues in the desert. :wave:
Jim Jim Jim!!!
You know the 35s on the Bronco 8.8 work just fine!!
And of course this wouldn't have anything to do with your opinion?I will jump in and say my .02$ worth..
to the original poster.. Dump the D44 rear, and start building a 35 spline ford 9"..
a ton of support and inexpensive aftermarket racing products everywhere.. stay away from the crappy Chinese axles that many vendors push. I would go with a set from Moser or Dutchman.
This in my opinion is the only way to go for a jeepspeed or prerunner..
http://www.naxja.org/forum/showthread.php?t=1070675
For a Jeepspeed? Sure, 9" is the way to go. For a weekend warrior / prerunner? 9" is overkill. If you can afford it, awesome, but for someone who doesn't want to drop $2000+ on an axle, a D44 will work fine (for the millionth time)
Nope not at all.. cheaper to part out my xj then sell it complete.. has nothing to do with my recommendation. Id still run a custom 9" that will last 10 times longer than a d44.
i suppose that would be a modified tech form question huh.
