- San Diego
me thinks you should sell those rear shock towers...
Vanimal said:nice, those rear shock towers look almost exactly like mine lol
Just be sure to cycle it carefully before you go all out, maybe flex it out on a forklift little by little so you can check out shock to body clearance. I suspect you may have an issue while fully articulated, but it's hard to say since leafs may act differently with axle swing than my links did (either for the better or for the worse, i couldnt guess).
Cool, glad someone is doing it. You can fit coilovers without rubbing on stock width axles, however you'll be limited to 2.0's and probably 14" length. I had 16" coilovers in the rear, and it was a damn close fit when i had a xj d44 and 35's. I found that the higher the lower shock mounts are on the axle, the less the shock swings. Mine were at least a few inches above the top of the axle. This works with a triangulated 4 link, but i dont think it will work with a 3 link (i'm not sure if outboard shocks will fit whatsoever with a 3 link and stock width axles due to axle swing) and i'm not too sure with leafs.Thanks guys!
That's the plan. We'll offer a "DIY" kit with the bare parts. I am going to thoroughly test them out however before we offer them.
You caught me lol. Your build did inspire me to develop my own tower though. After all It just makes sense on a uni-body.
Before I got very far with the fab work, I did flex test it to ensure the shock doesn't contact the tower. Having the shock position pushed out as far as possible at the leaf plate was pretty much a requirement. Also a 2.5" shock or coilover would damn near require a "full width" axle. :cheers:
keep the top width the same and widen the bottom a couple of inches.
