- Rainy side of Washington
I can't believe they actually made it easier to install those cursed manifold bolts. I swear I needed a couple extra elbows to get mine on last time. It's way easier if you pull the air filter housing, gives you some space to work.
Any idea if the manifold is compatible with the various years of idler pulley / PS pump? I know from 87-95 the PS pump bracket moved with the adjuster, on 96 vehicles another idler was added that moved and the PS pump was stationary, and on 97-01 the design was similar to 96 but changed slightly iirc. All this applies to LHD, the RHD vehicles moved the alternator up and put the AC compressor where the idler on 96-01 LHD is, haven't worked on an RHD yet so I have no hands on experience with them.
